Need help with column shifter problem 353
Jeff353W
1984 353s
1981 353 Projekt/Teilespender
Ungelesener Beitragvon Jeff353W » Sonntag 8. November 2015, 17:42
Sorry aout the use of English again but let me explain: The little 2-piece plastic ball on the shifter lever popped out and won't stay in. What is supposed to keep it in there? Is something broken or mis-adjusted somewhere in the linkage to make it fall out? I can try posting a picture if this is not clear. I can see nothing there to keep the ball in place on the shift lever.
Thanks!
Jeff
1976 Wartburg 353 Deluxe
Fredericksburg, Virginia
Re: Need help with column shifter problem 353
Ungelesener Beitragvon Tomtom » Sonntag 8. November 2015, 18:58
Jeff353W
1984 353s
Ungelesener Beitragvon Jeff353W » Sonntag 8. November 2015, 21:13
OK thanks for the link. It looks like my Gabelhebel is broken. The top end that is supposed to hold the plastic ball has separated. I will have to replace that for sure. But I'm still wondering whether there is a temporary fix I could apply to drive it in the meantime.
Thanks very much!
Jeff
Ungelesener Beitragvon Tomtom » Sonntag 8. November 2015, 21:54
I dont know any temporary solution for a broken lever.... :-(
But may be it is not broken.
In my case the bolt from the lever was moveable so the "Gabelhebel" was not in the place where it should be.
Ungelesener Beitragvon WABUFAN » Montag 9. November 2015, 05:41
Please, looks here:
viewtopic.php?f=2&t=10189
I have solved this thus...
Jeff353W
1984 353s
Ungelesener Beitragvon Jeff353W » Mittwoch 11. November 2015, 01:25
In my case the Gabelhebel is still attached to the column just fine. The "collar" that holds the kunststoff Kugel on the end (and keeps the lever in the right place to move the lever to find the gears) has broken off and the Kugel dropped out and now the lever goes all over but can't find the gears unless you push it way in and really look for the gears. At first I just thought there was something missing that was supposed to hold the Kugel in there but it is supposed to actually be attached to the Gabelhebel and it's not anymore. I was thinking I could hold it in there with a clamp or something temporarily, but I will just wait until my order gets here from Danzer Autoteile.
Ungelesener Beitragvon Tomtom » Mittwoch 11. November 2015, 21:08
Pls. put a picture to see what is broken. Eventually somebody has an idea...
Friedolin
Ungelesener Beitragvon Friedolin » Donnerstag 12. November 2015, 19:02
Yes, pictures would be great! Perhaps you can tell us by using the exploded drawing at Autoteile Baller, what actually has failed? Here is the link:http://autoteile-baller.de/start.htm (Click W353, then "Fahrgestell", then "Lenksäule")
Ungelesener Beitragvon Warre 1000 » Donnerstag 12. November 2015, 19:58
The 2-pieced plastic ball have also fall out by me. The red arrow shows were the fork was broken into two pieces. The round thing was no longer attached to the fork and it was possible to pull it out, when putting in reverse gear. That allowed the plastic parts to fall out. And it was very hard to change gear.
Jeff353W
1984 353s
Ungelesener Beitragvon Jeff353W » Donnerstag 12. November 2015, 21:23
Yes Stig exactly that is what has happened. I think I'm just stuck waiting for the new Gabelhebel to get here from Danzer.
Here is how it is supposed to look under the cover:
And this is how it looks now (the end of the Gabelhebel with the ball on it has broken off and floats free out of the column):
Stig did you figure out any temporary repair or did you just replace the Gabelhebel?
Ungelesener Beitragvon Warre 1000 » Donnerstag 12. November 2015, 21:53
No, I do not have any tempory fix, but Wabufan have one. It is to fasten a handle on to the round bar under the dashboard. Not comfortable to use but working. Look at the fifth picture in Wabufans link.
It might be some help to put a hose clamper preventing the broken part to come out. But putting in reverse gear you have to keep it in place by left hand and trying changing gear with the right hand.
Jeff353W
1984 353s
Ungelesener Beitragvon Jeff353W » Dienstag 15. Dezember 2015, 02:51
Sorry es so lang dauerte bis ich soweit gekommen bin: ich habe die Schaltung zerlegt und das Problem bestaetigt.
Habe Neuteil von Danzer am Schalthebel installiert. Muss jetzt wieder im Auto einbauen nur.
Gruesse der Jahreszeit an euch Alle aus Virginia!
Jeff
Ungelesener Beitragvon WABUFAN » Dienstag 15. Dezember 2015, 06:51
Grüsse nach Virginia !
Meine Lösung : viewtopic.php?f=2&t=10189
